  3. DRC
  • Views 13046
DRC
vadi
vadi over 7 years ago
Hi
I have noticed that during DRC in OrCad capture if pins are passive and not connected there are no warnings. Is there a way to check all unconnected pins and single net nodes?
thanks vadim
  • Alok Tripathi
    Alok Tripathi over 7 years ago
    Select following options in DRC > Electrical Rule TAB
    Check Single Node Nets
    Check Unconnected Pins
    Since these are warnings, not an error, you should also select Create DRC markers for Warning in DRC options TAB.
