  3. 17.20: Unable to check out Capture after applying HotFix...
  • Views 783
17.20: Unable to check out Capture after applying HotFix 048 - Anyone else with this problem?
UlfK
UlfK over 7 years ago
Having found HotFix 048 in the support area I downloaded it and applied it this morning.
(Previously applied version was 047.)
Invoking Capture results in an error message "Unable to reach the license servers ...etc"
and that I should verify the CDS_LIC_FILE settings (which has not changed).
Invoking Allegro PCB Editor works fine.
Anyone else seen this?
  • UlfK
    With the help from Cadence support, the problem was found to be the semicolon used in the redundant server CDS_LIC_FILE definition. After changing the semi-colon to a comma, (OrCAD) Capture invoked normally.
