  3. Package Extraction with Allegro Package SI: Is it Possible...
  • Subscribers 162
  • Views 14761
Package Extraction with Allegro Package SI: Is it Possible?
archive over 20 years ago
Hi Everyone, I'm glad I could join! My question: Allegro package SI documentation says it is possible to extract package models using the 3d field solver, but I heard that this option still does not work properly, is this the case? I need to get an IBIS model of a package, and I would like to know if Allegro Package SI can do this before I invest time on learning it. Thanks for your help.
Originally posted in cdnusers.org by mieltawil
    Mieltawil,
    A full package model can be generated either from Allegro Package SI 620, or Allegro Package Designer 620 (I assume we are referring to the 15.5.1 release). IBIS is, indeed, one of the options for that model.
    This capability has been available for almost two years. Many of our customers use the 3D extraction module to extract entire package models (any other customers online?; please "chime in").
    Without the specifics of "does not work properly", I can't really speak to what you have heard. If you do find some specific issues, however, please work with your local AE or our CS personnel to get them resolved.
    I would encourage you to try it.
    Best Regards,
    Bill Acito
    Packaging Tech Marketing Manager
    Cadence - Chelmsford, MA
    Originally posted in cdnusers.org by BillAcito
    Thanks BillAcito. We have Allegro Package SI 620 and Allegro Package Designer 610, I think it's just the 15.5 release, not 15.5.1. I was told (and I don't believe it, that's why I'm here) that the 3d modeler kept crashing and could not extract bondwires, but now that I have info from the source (you), I will definately spend time on learning it. Thanks again.
    The only issue that I am aware of is if the bond wires were not created "correctly", meaning if they were created by say, "add connect" versus the wire bond tool set. In that case the wires would not have the correct properties applied and the extraction tool might have difficulty with the design.
    Bill
