  3. How to create a multilayer spiral inductor in allegro pcb...
  • Subscribers 162
  • Views 8539
How to create a multilayer spiral inductor in allegro pcb librarian 17.2?
FormerMember
FormerMember over 8 years ago
  • steve
    steve over 8 years ago
    You could either import the dxf of the spirals to create copper shapes, use vias to connect the spirals. Then have a pins 1 and 2 for the start and end points. Save then when you use this in a board users can add the net_short property on the pins and vias to short the two nets together. There is also a free app that may help make the spirals orcadmarketplace.com/.../Default.aspx
  • FormerMember
    FormerMember over 8 years ago in reply to steve
    Thanks..it helped a lot
