  3. Exporting STEP files of parts in 3d PDF from 3d canvas
  • Subscribers 166
  • Views 15657
tinyspud
tinyspud over 6 years ago
Hi
I'm having a couple of issues with the step models in the 3d viewer in OrCAD pro.  First is that one of the parts I have has a step file which is made up of multiple components (it's a dev module) and everything in it scales fine but the USB connector on it is scaled to like 40x.  I'm not sure if it's something in a setting or if it's something I can change with another program then reexport or what but basically I'm seeing a gigantic micro USB port when I import the model.  The step file from digilent is here:
https://reference.digilentinc.com/_media/reference/programmable-logic/cmod-a7/cmod_a7.zip
The other question is that in the 3d canvas I have several parts set up with step files but every time I export the 3d pdf it exports the board and all of that information fine except it just places the black boxes from the package boundaries so when I send the rendering out it just has a bunch of boxes.
I'm not sure if it's just something I'm missing (I'm really unfamiliar with 3D CAD) but any help on either would be appreciated
Thanks!
  • steve
    steve over 6 years ago
    Try opening the step models you have in FreeCAD (download from the web for free). Then just save them again as a STEP model and try and use them again.
  • tinyspud
    tinyspud over 6 years ago in reply to steve
    Perfect - that did it.  Anyone know how to get this 3D pdf export to include the step models if they're available and if not then use the place_bound boxes?  I'm only able to export them one way or the other.... I found a previous solution that was in the setup preferences that had the model preferences
  • tinyspud
    tinyspud over 6 years ago in reply to tinyspud
    okay or not - now it works fine.  I'm not sure what happened but I have my PDF.  Thanks Steve!
