  3. The value of the $SPLIT_INST_NAME or LOCATION property on...
  • Views 13709
The value of the $SPLIT_INST_NAME or LOCATION property on instance XXX is not specified
PaoloUoB
PaoloUoB over 7 years ago
Good afternoon,
while using Allegro Design Entry HDL 17.2 I got the warning shown in the title.
I place a component (LTC6903) and, as far as I can tell, this should not be a split component. However I get the warning and the following detailed message:
"Description : WARNING(SPCOCD-23): The value for the $SPLIT_INST_NAME or LOCATION property on instance: ltc6903, pathval: i14 is not specified.
You must specify a value for the LOCATION property if the SPLIT_INST = TRUE property is present on the instance
or specify a value for the $SPLIT_INST_NAME property on the instance."
Could anyone explain what the message means and how to get rid of it?
Many thanks,
Paolo
