  3. Ignore component in the netlist
  • Subscribers 166
  • Views 18080
Filo88
Filo88 over 7 years ago
Hi everyone,,
I  trying to ignore a component in the netlist but I not have had  successful.
I want to have a component in the BOM but I wan't it in the netlist ( for import in allegro).
I tried the SPiceOnly property but in this case I don't have the component in the netlist and also in the bom.  I see the BOM_IGNORE property. Is there a same property for PCB footprint (ex. PCB FOOTPRINT_IGNORE or NETLIS_IGNORE) ? How can I solve this problem?
Thanks.
Filippo
  • oldmouldy
    oldmouldy over 7 years ago
    In 17.2, you can use the NETLIST_IGNORE property assigned to the Part, set the property Value to TRUE. The part will then be in the BOM but not in the netlist.
  • Robert Finley
    Robert Finley over 7 years ago
    If the schematic symbol has no pins, it will not be mentioned in the netlist.
    This cheat allows us to keep track of hardware and jumper block ordering info in the CIS/CIP system.
    Each part uses a schemo symbol that is a simple rectangle.
  • Filo88
    Filo88 over 7 years ago in reply to oldmouldy
    Thanks, I fixed the problem. I use NETLIST IGNORE property. I discovered also BOM_ IGNORE.
