  3. shape min thickness
  • Views 15275
shape min thickness
TreeCity
TreeCity over 7 years ago
Hi All,
Is there a way to set the shape minimum thickness?
Thanks.
  • TreeCity
  • TreeCity
    TreeCity over 7 years ago in reply to TreeCity
    I am talking about the small thickness of the blue shape between yellow and green pads.
  • oldmouldy
    oldmouldy over 7 years ago in reply to TreeCity
    If you want to remove the connection, look at Shape>Global Dynamic Parameters (all Shapes), or Select the Shape and right-click>Parameters for an individual Shape, then the Void Controls tab, experiment with increasing the settings "Minimum Aperture for Gap Width", about 0.05mm (2Mil) increments, "Suppress Shapes Less Than", about 0.1mm / 0.15mm (4Mil / 6Mil) increments. There will be side effects within the Shape as you tweak these so large increments / values are probably not recommended.
  • TreeCity
    TreeCity over 7 years ago in reply to oldmouldy
    thank you for your detailed reply. It is working as you described and resolved my problem.
