  3. Setting Layout constraints in ORCAD Capture schematic
  • Views 14533
Gowtham229
Gowtham229 over 7 years ago
Can any one tell me how to navigate through ORCAD capture CIS to set PCB layout constraints which help me saving time...is it possible to set constraints like grouping/class-class spacing,pinpair etc in capture instead of allegro pcb
Your suggestion will be very helpful for everyone
Gowtham
  • B Bruekers
    B Bruekers over 7 years ago
    You cannot do this yet. In the comming 17.2 Hotfix 49 the same constraint manager shall be available in Capture.
  • Gowtham229
    Gowtham229 over 7 years ago in reply to B Bruekers
    Thanks Bruekers Can't we set physical,spacing csets as well...
  • B Bruekers
    B Bruekers over 7 years ago in reply to Gowtham229
    Yes you will be able to do this in capture but you will need to import the constraints from a PCB design since Capture does not have any stackup information or editor.
  • Gowtham229
    Ok thank you very much i will try to work out on it..
