  3. tlsim error!!! help?where fing simulator commmand line
  • Subscribers 163
  • Views 1446
archive over 19 years ago
when i use probe in pcb SI to create waveform,the error happen . in tlsim.log ,it report as below:
 **** Tlsim Version 14.1 ****
 Tue Jun 27 18:14:20 2006
**** Tlsim command line ****
 tlsim -r 0.200000 -EIndVsrcDc -o waveforms.sim -dl delay.dl -dst distortion.dst -log tlsim.log -ocycle cycle.msm main.spc
Number of Nodes in this circuit = 77
Statistics on N-line elements:
 Number of 'n' type multi-conductor elements = 18
 Type-of-N-element  #elms Max_Length TotalLength
 1-line-N-elm     18   0.0528074    0.163241
 Total Interconnect Length = 0.163241
 Total Coupled Length = 0
 Following is some statistics on Model usage
   Model-Type      Model-Name     Number-of-Models-in-this-circuit
   bdrvr         MPC8220_SSTL_CLK_clksstl2class2_Typical               1
   bdrvr         DQ_FULL_Typical               1
   bdrvr         256MDDR_I_O_DQ_Typical               1
  No of 'Bdrvr' type model instance = 3
 Time Step at Start = 1.86667e-011
  ABORT!: MATRIX FACTORIZATION FAILURE IN DC
 possible causes of this mishap are
1. Modelling inductors as ideal inductors:
try using the switch -EIndVsrcDc in the simulator command line.
This will model the inductors with small real dc resistance.
2. Look for dc offset currents in v-i data . If you have offset currents
you certainly need dc terminations!!
**** Transient Simulation Statistics ****
    Number Of time step solutions = 0
i donot know how to do!
can you tell me ?
thks!!
   best regard!!
Originally posted in cdnusers.org by upton_zhou
    thanks ,Keskinen!!
    i have tried this way you tell me above yesterday. and the same status happened.
    expect you reply!
    thks
    thanks ,Keskinen!!
    expect you reply!
    thks
