  3. Capture CM crashes
  • Views 14657
Capture CM crashes
MAAC
MAAC over 7 years ago
Capture tool is getting crashed whenever i invoke the newly introduced Constraint manager(capture) in ISR48(17.2) . Updated to ISR 49 as well and renamed Capture.ini folder along with deleting Capture workspace in regedit but no results.
Any other workaround or solution
  • Lock2002
    Lock2002 over 7 years ago
    try this: run RegEdit.exe and change the key HKEY_CURRENT_USER\Software\EMA\CMforOrCAD\Settings\UseRibbon from 0 to 1.
  • MAAC
    MAAC over 7 years ago in reply to Lock2002
    im not finding this key in my PC. Checked in colleague PC where CM is working even their is no EMA\ key available.
