  3. Rollback HF S049?
  • Views 12940
Rollback HF S049?
Tmills
Tmills over 7 years ago
If you installed HotFix S049, can you install HotFix S048 back over the top of it?
  • excellon1
    excellon1 over 7 years ago
    Its possible if you backed up your prior version during the SO49 update. If not then you have to install from scratch ( base install) then apply your update. If you go the uninstall route you don't have to uninstall the licensing. On a fresh install don't install the licensing just the base product you have. As a precaution backup your pcbenv & cdsetup first. Typically these are located in the c:\SPB_Data folder.
    When installing choose the option "Install for all users"
