  3. how uncolor nets
  • Subscribers 163
  • Views 15540
how uncolor nets
liviovalerio
liviovalerio over 7 years ago
Hi, is there a command or skill to uncolor nets?
I have searched under u commands and i not have find an uncolor command.
Is there the possibility to create a such command of method (by skill language) to create a button the works (like assign color) (in the opposte way) to uncolor nets selected?
thanks for any reply.
Artwork
  • DavidJHutchins
    DavidJHutchins over 7 years ago
    (axlClearObjectCustomColor ((axlDBGetDesign)->nets))
  • mcatramb91
    mcatramb91 over 7 years ago
    Using the Dehighlight command (Display > Dehighlight) there is a setting under the Option tab to Retain the Custom Color or not.  Uncheck it and select the Nets or all Nets to remove the color settings.  This can also be done under the Nets section of the Color Dialog using the "Clear All Nets" button.
    Hope this helps,
    Mike Catrambone
