  3. Move a line segment
  • Replies 9
  • Views 18990
Move a line segment
paex30
paex30 over 7 years ago
I want to move a line segment in a precise location using coordinates. How could I do?
  • oldmouldy
    oldmouldy over 7 years ago
    Assuming a default PCB Editor installation in General Edit Application Model, hover over the item, right-click>Move, then left-click in the PCB Editor Command Window and type "x <xLocation> <yLocation>" like "x 20 50" to place at x=20 and y=50, Command needs a lower case x and spaces between the parameters, press enter to accept the command.
  • paex30
    paex30 over 7 years ago in reply to oldmouldy
    Ok but I in this way I specify only one set of coordinates and I don't know at what point in the segment the coordinates are associated. Is there a way to move both the edges of segment and so specify two set of coordinates?
  • CadAce2K
    CadAce2K over 7 years ago in reply to paex30
    With 'line' element in find filter, hover over the line; RMB (snap -> to segment center) and it should select the midpoint of the segment. Then do like Oldmouldy mentioned. Once you master the 'snap' function of Allegro, you'll be a amazed what you can do.
  • CadAce2K
    CadAce2K over 7 years ago in reply to CadAce2K
    You can also do the same with the line's vertex. Hover over the line's endpoints and 'snap -> to segment vertex  and with coordinates you can move them precisely where you desire.
  • paex30
    paex30 over 7 years ago in reply to CadAce2K
    After RMB I don't see the snap option
