  3. SERIOUS convergence problem in simulation
  • Subscribers 163
  • Views 13655
archive over 19 years ago
when i try to simulate net in specctraquest during post simulation at pulse 133mhz  i find this error
"warning: SERIOUS convergence problem in simulation"
can any one tell me the reason- this is becos of model or something else
how can i remove this so that i can simulate the net and check the waveform
Originally posted in cdnusers.org by nikhilbny
    I don't know your topology but some things you can try:
    a) Just drive the output into the input over a simple T line at your operating frequency. If you get the same error, remove the v-t curves and see if it works.
    b) If the output into the input works, start adding the bits of your topology to see where it fails.
    c) Also, try to change the time step setting to a finer time step.
    Originally posted in cdnusers.org by Kalevi2
    You should also look in the tlsim.log file down in your /sim directory since it will often give you additional information. Other than that, Kai's suggestion to try subsets of your circuit is a good one.
    Originally posted in cdnusers.org by Donald Telian
