  3. 17.2 Padstack Editor -- Opening scripts for 16.6 in 17.2...
  • Replies 8
  • Views 5500
17.2 Padstack Editor -- Opening scripts for 16.6 in 17.2?
JFuoco
JFuoco over 6 years ago
Is there a simple way to open padstack scripts written for v16.6 in padstack editor v17.2? It seems like a complete scripting language overhaul.
The root of this problem is that I exported a design from TI's WEBENCH tool. However the padstack scripts don't seem to work at all in v17.2. The first issue that occurs is "Can't find window; Form.padedit"
Here's a sample part of the script:
######################## New PadStack #########################
pse_new
fillin "R10180550000000A.pad"
FORM padedit units Mils
FORM padedit decimal_places 4
FORM padedit layers
FORM padedit grid row 1
FORM padedit geometry Rectangle
FORM padedit width 17.7165
FORM padedit height 55.1181
FORM padedit x_offset 0
FORM padedit y_offset 0
FORM padedit geometry_th Null
FORM padedit grid row 4
FORM padedit grid row 6
FORM padedit parameters
FORM padedit single YES
FORM padedit plating Non-Plated
pse_save_as
Here's a snippet from a script I started recording in v17.2:
# Pad Editor script
# file: 123.scr
# start time: Wed Dec 19 2018 16:35:30
# Version: 17.2 S033 (3691042) Windows SPB 64-bit Edition
QtSignal GuidedTabsParent PadstackTypes currentRowChanged 1
QtSignal GuidedTabsParent PadstackTypes itemSelectionChanged "SMD Pin"
QtSignal GuidedTabsParent PadstackTypes itemClicked "SMD Pin"
QtSignal GuidedTabsParent GuidedStartTab keyPressEvent 16777249 67108864 false 1
QtSignal MainWindow Units CurrentIndexChanged Millimeter
QtFillin Yes
QtSignal MainWindow Units CurrentIndexChanged Mils
QtFillin Yes
  • steve
    steve over 6 years ago
    The biggest issue is probably the name of the exe that is first called up. 17.2 uses padstack_editor.exe and 16.6 used pad_designer.exe. Look at the script file and see if that helps
  • JFuoco
    JFuoco over 6 years ago in reply to steve
    Hi Steve thanks a lot. Confirmed, the original .exe calls pad_designer.exe:
    Beginning of original script:
    cd %~dp0
    allegro -s CustomShapes.scr
    pad_designer -s 2018-12-18_14-22-36_pads.scr
    My edits, to work for 17.2:
    cd %~dp0
    C:\Cadence\Cadence_SPB_17.2-2016\tools\bin\allegro.exe -s CustomShapes.scr
    C:\Cadence\Cadence_SPB_17.2-2016\tools\bin\padstack_editor.exe -s 2018-12-18_14-22-36_pads.scr
    I also tried opening the 2018-12-18_14-22-36_pads.scr script inside padstack editor directly to see if it runs, but thats where i get the error above:
    Any thoughts?
  • steve
    steve over 6 years ago in reply to JFuoco
    I think this was where you used to browse for a shape symbol file in the v16.6 Pad Designer. You may have to try and access a 16.6 installation to run the scripts then once complete open them up with 17,2 Padstack Editor. If you can't access them attach them here and I can do this for you.
  • JFuoco
    That'd be great Steve. Here's the zip I had downloaded from TI: 2018-12-18_14-22-36.zip
  • steve
    Here you go data.zip
