  3. COMPONENTS OVERLAP DRC
  • Views 15352
ColinLiu
ColinLiu over 6 years ago
Hi expert,
There is special case that I have to overlap two components  to reserve two kind of footprint.
I can understand the overlap DRC error on this case.
But there are still two other DRC type I do not know how to deal with.
One is rats: It seems just can be route/connect to one symbols pin while another one is can not accesible. So the rats exsit.
Am i should route all the two pins in different components? It seems i can not do it. How should I deal with this DRC error?
Another one is: Drill hole to line same net spcaing(because the footprint is dirllhole)
I guess this error is caused by the line and another pin which I do not connect.(I try to delete one symbols footprint and this DRC disappear)
How can i deal with this kind of error.
I think there are some cases that you have to reserve two footprint. Please teach me some about it. Thanks
  • B Bruekers
    B Bruekers over 6 years ago
    My suggestion is to make 1 footprint which does not have any padstacks, so basically a mechanical footprint. Then you can overlay these 2 footprints without any pin/connection issues.
    In one case I had to place 2 TH transformers 90deg. rotated on top of eachother and only 1 pin was matching in location. So In 1 component I added 'unfix pins' property to this pin, changed the padstack to a SMT testpad and moved it away from the pin which was already there (from the 2nd component).
    Kr, Bram
  • ColinLiu
    ColinLiu over 6 years ago in reply to B Bruekers
    I think your method must be workable.Thanks
