  3. Tab Key issue in PCB Designer 17.2.050
  • Views 12739
Nicow
Nicow over 6 years ago
Hi all,
Since the update to the 17.2 version, I have been encountering an issue in PCB designer professional with the tab key which toggles the selection between the different selected elements of the filter. The software always reacts as there were more key stroke than one.I have found a workaround with the RMB menu and toggle select command, but it requires more clicks than the tab key stroke.
I hoped this would have been solved in the previous hotfix (050), but apparently not. This issue is not even listed in the CCR.
Do you also get the same behaviour? How can I submit a CCR by myself?
Thanks for your help and kind regards,
Nicolas
