  3. Custom report generation
  • Subscribers 163
  • Views 15907
JD Mill
JD Mill over 7 years ago
I am trying to create a custom report in Orcad PCB Editor that outputs the internal Part Number we have assigned.
My schematic  symbol has defined a property of "User Part Number". That creates Attached text:
   class      = USER PART NUMBER
   subclass   = ASSEMBLY_TOP
   value      = 5041210
in the footprint.
My question is what do I need to add to the symbol to get the part number to show up in the report using:
# This is an extract command file
# generated by the Extract UI.
COMPONENT
REFDES
REFDES_SORT
SYM_CENTER_X
SYM_CENTER_Y
PART_NUMBER
END
  • KMani
    KMani over 7 years ago
    Try with COMP_PART_NUMBER, it will list all part number assigned with the component.
    COMPONENT
    SYM_NAME
    REFDES
    REFDES_SORT
    COMP_PART_NUMBER
    SYM_X
    SYM_Y
    SYM_ROTATE
    SYM_MIRROR
    END
