  3. Encryption of Capture tcl script
  • Views 14649
MartinAA
MartinAA over 6 years ago
I need to encrypt a sensitive Capture tcl script. Page 106 of the Capture tcl/tk Application Note mentions the ''orcad::encrypt" command, however when I try to run from the Capture Command Window I get:
[ 1]invalid command name "orcad::encrypt"
I am using Capture 17.2-2016. Could you please advise ?
Many thanks.
  • oldmouldy
    oldmouldy over 6 years ago
    This is covered in the "Getting Started with OrCAD TCL 17.2-2016" manual on the Cadence Support site. The encryption is now done by compiling the script since the orcad:: encrypt command is no longer supported.
  • MartinAA
    MartinAA over 6 years ago in reply to oldmouldy
