  3. Allegro 17.2 Slot tolerance numbers
  • Views 13736
FormerMember
FormerMember over 6 years ago
Hi All:
How do I get slot tolerance numbers from padstack into drill legend.
Currently only X tolerance shows up not the Y tolerance
Also, slot tolerance does not show up in drill customization chart.
Les
  • steve
    steve over 6 years ago
    There is an option to display this under Manufacture - NC - Drill Legend, check the box for Tolerance drill:-
    Edit - The Y Tolerance will be shown if you enable the checkbox for Tolerance travel
