  3. Notch and Slide options in Edit Shape Operation
  • Views 15447
chadga
chadga over 7 years ago
I am using OrCAD PCB Designer Professional 17.2 with hotfix(050). If I want to edit the board outline using Shape Select to add a notch, there is no option available to do that. In the previous hotfix version I could easily add notch and slide only a small part of a line segment. There is no option available in the latest hotfix when I go to shape select and pick the board outline.
Kindly help me on this issue.
  • steve
    steve over 7 years ago
    Make sure you are in Shape Edit Mode (Setup - Application Modes - Shape Edit) then look at the Options Pane
  • chadga
    chadga over 7 years ago in reply to steve
    Thank You Steve.
