  3. Creating Netlist--Error(ORCAP-32007):Netrev failed. Please...
  • Replies 7
  • Views 11655
Creating Netlist--Error(ORCAP-32007):Netrev failed. Please refer to Session log or netrev.lst for details.
StepscanDarcy
StepscanDarcy over 6 years ago
Hey all,
I've been tasked with replacing a 30 pin connector on our boards, with a new one after the old one was declared obsolete.    I've updated the schematic by altering the old connector and saving/update/replace cache. When I try to create the netlist to bring the changes to pcd editor, I am met with an error.
ORCAP-32007 or ORCAP-32006
I am completely new to PCB design, so I may have made a fatal error early on that's preventing me from doing this?
Is there an easy way to replace components?   I'd like to keep all of the same connections to the same pins, and just replace the symbol/footprint.
cpu time 0:01:02
elapsed time 0:00:00
INFO(ORCAP-32005): *** Done ***
INFO(ORCAP-32002): Netlisting the design
INFO(ORCAP-32004): Design Name:
C:\USERS\DARCY\DESKTOP\ORCAD TRAINING\TRAINING\TCC\TCC_0458-0000_REV2_SCH_14-12-02C.DSN
Netlist Directory:
C:\USERS\DARCY\DESKTOP\ORCAD TRAINING\TRAINING\TCC\allegro
Configuration File:
C:\Cadence\SPB_17.2\tools/capture/allegro.cfg
Spawning... "C:\Cadence\SPB_17.2\tools\bin\pstswp.exe" -pst -d "C:\USERS\DARCY\DESKTOP\ORCAD TRAINING\TRAINING\TCC\TCC_0458-0000_REV2_SCH_14-12-02C.DSN" -n "C:\USERS\DARCY\DESKTOP\ORCAD TRAINING\TRAINING\TCC\allegro" -c "C:\Cadence\SPB_17.2\tools/capture/allegro.cfg" -v 3 -l 31 -s "" -j "PCB Footprint" -hpath "HPathForCollision" -lite
#1 WARNING(ORCAP-36038): "No_connect" property on Pin "RP3.16" ignored for RP3: TMDSSK3358-1V2A, Pg05: DDR3_Memory (14.60, 5.30). Connecting pin to net "VTT_DDR".
#2 WARNING(ORCAP-36038): "No_connect" property on Pin "U1.D14" ignored for U1: TMDSSK3358-1V2A, Pg02: AM335X Section 1 of 3 (6.30, 4.10). Connecting pin to net "PMIC_INT1_GPIO".
#3 WARNING(ORCAP-36038): "No_connect" property on Pin "U25.A2" ignored for U25: TMDSSK3358-1V2A, Pg13:FPGA_Power (0.00, 0.00). Connecting pin to net "N28640936".
#4 WARNING(ORCAP-36038): "No_connect" property on Pin "U25.A4" ignored for U25: TMDSSK3358-1V2A, Pg13:FPGA_Power (0.00, 0.00). Connecting pin to net "N28640939".
#5 WARNING(ORCAP-36038): "No_connect" property on Pin "U25.A5" ignored for U25: TMDSSK3358-1V2A, Pg13:FPGA_Power (0.00, 0.00). Connecting pin to net "N28640942".
#6 WARNING(ORCAP-36038): "No_connect" property on Pin "U25.A6" ignored for U25: TMDSSK3358-1V2A, Pg13:FPGA_Power (0.00, 0.00). Connecting pin to net "N28640945".
#7 WARNING(ORCAP-36038): "No_
connect" property on Pin "U25.B1" ignored for U25: TMDSSK3358-1V2A, Pg13:FPGA_Power (0.00, 0.00). Connecting pin to net "N28640948".
#8 WARNING(ORCAP-36038): "No_connect" property on Pin "U25.B3" ignored for U25: TMDSSK3358-1V2A, Pg13:FPGA_Power (0.00, 0.00). Connecting pin to net "N28640951".
#9 WARNING(ORCAP-36038): "No_connect" property on Pin "U25.B4" ignored for U25: TMDSSK3358-1V2A, Pg13:FPGA_Power (0.00, 0.00). Connecting pin to net "N28640954".
#10 WARNING(ORCAP-36038): "No_connect" property on Pin "U25.B5" ignored for U25: TMDSSK3358-1V2A, Pg13:FPGA_Power (0.00, 0.00). Connecting pin to net "N28640957".
#11 WARNING(ORCAP-36038): "No_connect" property on Pin "U25.B6" ignored for U25: TMDSSK3358-1V2A, Pg13:FPGA_Power (0.00, 0.00). Connecting pin to net "N28640960".
#12 WARNING(ORCAP-36038): "No_connect" property on Pin "U2.3" ignored for U2: TMDSSK3358-1V2A, Pg02: AM335X Section 1 of 3 (10.40, 12.80). Connecting pin to net "RTC_PORZ".
#13 WARNING(ORCAP-36038): "No_connect" property on Pin "Y4.2"
ignored for Y4: TMDSSK3358-1V2A, Pg13:FPGA_Power (13.90, 5.30). Connecting pin to net "DGND".
#14 WARNING(ORCAP-36038): "No_connect" property on Pin "U1.V2" ignored for U1: TMDSSK3358-1V2A, Pg03: AM335X Section 2 of 3 (4.20, 3.50). Connecting pin to net "NSTATUS".
#15 WARNING(ORCAP-36038): "No_connect" property on Pin "U18.25" ignored for U18: TMDSSK3358-1V2A, Pg09: RGMII1 (5.90, 3.50). Connecting pin to net "CLK_25M".
#16 WARNING(ORCAP-36038): "No_connect" property on Pin "U1.R1" ignored for U1: TMDSSK3358-1V2A, Pg03: AM335X Section 2 of 3 (4.20, 3.50). Connecting pin to net "AM335X_READY1".
#17 WARNING(ORCAP-36038): "No_connect" property on Pin "U1.V4" ignored for U1: TMDSSK3358-1V2A, Pg03: AM335X Section 2 of 3 (4.20, 3.50). Connecting pin to net "AM335X_READY2".
#18 WARNING(ORCAP-36038): "No_connect" property on Pin "Y4.4" ignored for Y4: TMDSSK3358-1V2A, Pg13:FPGA_Power (13.90, 5.30). Connecting pin to net "V3_3D".
#19 WARNING(ORCAP-36038): "No_connect" property on Pin "U18.6" ignored for U18: TMDS
SK3358-1V2A, Pg09: RGMII1 (5.90, 3.50). Connecting pin to net "N28109108".
#20 WARNING(ORCAP-36038): "No_connect" property on Pin "U25.C1" ignored for U25: TMDSSK3358-1V2A, Pg12:FPGA_Interface (11.90, 2.70). Connecting pin to net "FPGA_ADSO".
#21 WARNING(ORCAP-36038): "No_connect" property on Pin "U1.A15" ignored for U1: TMDSSK3358-1V2A, Pg02: AM335X Section 1 of 3 (6.30, 4.10). Connecting pin to net "AM335X_FPGA_CONFIG_DONE".
#22 WARNING(ORCAP-36038): "No_connect" property on Pin "U1.B12" ignored for U1: TMDSSK3358-1V2A, Pg03: AM335X Section 2 of 3 (4.20, 3.50). Connecting pin to net "AM335X_FPGA_NCONFIG".
WARNING(ORCAP-40304): Could not export models as the models used in the design C:\USERS\DARCY\DESKTOP\ORCAD TRAINING\TRAINING\TCC\TCC_0458-0000_REV2_SCH_14-12-02C.DSN are not present in the search path.
Check if the model libraries are configured.#23 WARNING(ORCAP-36006): Part Name "18PFCAPACITOR50V5%0402_SM-7351-CAP-0402_18PF, 50V" is renamed to "18PFCAPACITOR50V5%0402_SM-7351-".
#24 WARNING(ORCAP
-36006): Part Name "1UFC
APACITOR10V10%0402_SM-7351-CAP-0402_1UF" is renamed to "1UFCAPACITOR10V10%0402_SM-7351-".
#25 WARNING(ORCAP-36006): Part Name "0.1UFCAPACITOR16V10%0402_SM-7351-CAP-0402_0.1UF" is renamed to "0.1UFCAPACITOR16V10%0402_SM-735".
#26 WARNING(ORCAP-36006): Part Name "10UFCAPACITOR16V10%0805_SM-7351-CAP-0805_10UF" is renamed to "10UFCAPACITOR16V10%0805_SM-7351".
#27 WARNING(ORCAP-36006): Part Name "4.7UFCAPACITOR16V10%0603_SM-7351-CAP-0603_4.7UF" is renamed to "4.7UFCAPACITOR16V10%0603_SM-735".
#28 WARNING(ORCAP-36006): Part Name "0.01UFCAPACITOR16V10%0402_SM-7351-CAP-0402_0.01UF" is renamed to "0.01UFCAPACITOR16V10%0402_SM-73".
#29 WARNING(ORCAP-36006): Part Name "0.1UFCAPACITOR6.3V10%0201_SMD0603_0.1UF, 6.3V" is renamed to "0.1UFCAPACITOR6.3V10%0201_SMD06".
#30 WARNING(ORCAP-36006): Part Name "2.2UFCAPACITOR10V20%SMD0402_SM-7351-CAP-0402_2.2UF, 10V" is renamed to "2.2UFCAPACITOR10V20%SMD0402_SM-".
#31 WARNING(ORCAP-36006): Part Name "2.2UF16V10%SMD0805_SM-7351-CAP-0805_22NF" is renamed to "2.2UF16V10%SMD080
5_SM-7351-CAP-".
#32 WARNING(ORCAP-36006): Part Name "100UFCAPACITOR16V20%ELECTROPOLY_EDK107M063A9PAA_DNP" is renamed to "100UFCAPACITOR16V20%ELECTROPOLY".
#33 WARNING(ORCAP-36006): Part Name "0.1UFCAPACITOR6.3V10%0201_SMD0805_0.1UF, 100V" is renamed to "0.1UFCAPACITOR6.3V10%0201_SMD08".
#34 WARNING(ORCAP-36006): Part Name "10UFCAPACITOR16V10%0805_EDK106M063A9GAA_10UF, 63V" is renamed to "10UFCAPACITOR16V10%0805_EDK106M".
#35 WARNING(ORCAP-36006): Part Name "47UFCAPACITOR16V20%1206_SM-7351-CAP-1206_1.0UF" is renamed to "47UFCAPACITOR16V20%1206_SM-7351".
#36 WARNING(ORCAP-36006): Part Name "100UFCAPACITOR16V20%ELECTROPOLY_SM-7351-CAP-UE_150UF, 8V" is renamed to "100UFCAPACITOR16V20%ELECTROPO_1".
#37 WARNING(ORCAP-36006): Part Name "0.001UFCAPACITOR50V5%0402_SM-7351-CAP-0402_8.2NF" is renamed to "0.001UFCAPACITOR50V5%0402_SM-73".
#38 WARNING(ORCAP-36006): Part Name "2.2UF16V10%SMD0805_SM-7351-CAP-0805_100NF" is renamed to "2.2UF16V10%SMD0805_SM-7351-CA_1".
#39 WARNING(ORCAP-36006): Part Name "2.2UF16V10
%SMD0805_SM-7351-CAP-0805_330PF" is renamed to "2.2UF16V10%SMD0805_SM-7351-CA_2".
#40 WARNING(ORCAP-36006): Part Name "2.2UF16V10%SMD0805_SM-7351-CAP-0805_820PF" is renamed to "2.2UF16V10%SMD0805_SM-7351-CA_3".
#41 WARNING(ORCAP-36006): Part Name "2.2UF16V10%SMD0805_SM-7351-CAP-0805_390PF" is renamed to "2.2UF16V10%SMD0805_SM-7351-CA_4".
#42 WARNING(ORCAP-36006): Part Name "10UFCAPACITOR16V10%0805_SM-7351-CAP-0805_1000P, 1KV" is renamed to "10UFCAPACITOR16V10%0805_SM-73_1".
#43 WARNING(ORCAP-36006): Part Name "0.1UFCAPACITOR50V10%0402_SM-7351-CAP-0402_0.1UF" is renamed to "0.1UFCAPACITOR50V10%0402_SM-735".
#44 WARNING(ORCAP-36006): Part Name "27PFCAPACITOR10V5%0402_SM-7351-CAP-0402_27PF" is renamed to "27PFCAPACITOR10V5%0402_SM-7351-".
#45 WARNING(ORCAP-36006): Part Name "470PFCAPACITOR25V10%0402_SM-7351-CAP-0402_DNI" is renamed to "470PFCAPACITOR25V10%0402_SM-735".
#46 WARNING(ORCAP-36006): Part Name "0.1UFCAPACITOR6.3V10%0201_SMD0201_0.1UF, 6.3V" is renamed to "0.1UFCAPACITOR6.3V10%0201_SMD02".
#47
WARNING(ORCAP-36006): Part Name "47UFCAPACITOR16V20%1206_SM-7351-CAP-0805_22UF, 10V" is renamed to "47UFCAPACITOR16V20%1206_SM-73_1".
#48 WARNING(ORCAP-36006): Part Name "22PFCAPACITOR50V10%SMD0402_SM-7351-CAP-0402_22PF" is renamed to "22PFCAPACITOR50V10%SMD0402_SM-7".
#49 WARNING(ORCAP-36006): Part Name "0.001UFCAPACITOR50V5%0402_SM-7351-CAP-0402_0.001UF" is renamed to "0.001UFCAPACITOR50V5%0402_SM-_1".
#50 WARNING(ORCAP-36006): Part Name "DIODE_5ARECT_B520C-13-F_B520C-13-F" is renamed to "DIODE_5ARECT_B520C-13-F_B520C-1".
#51 WARNING(ORCAP-36006): Part Name "DIODE_5ARECT_B520C-13-F_B3100-13-F" is renamed to "DIODE_5ARECT_B520C-13-F_B3100-1".
#52 WARNING(ORCAP-36006): Part Name "DIODE_SMCJ7.0CA_SMCJ15CA_SMAJ54A" is renamed to "DIODE_SMCJ7.0CA_SMCJ15CA_SMAJ54".
#53 WARNING(ORCAP-36006): Part Name "FERBEAD_7_SM-7351-IND-0805_150OHM800MA" is renamed to "FERBEAD_7_SM-7351-IND-0805_150O".
#54 WARNING(ORCAP-36006): Part Name "FERRITEBEAD_3_HF70ACB201209_600MAFB10OHM" is renamed to "FERRITEBEAD_3_HF70ACB2012
09_600".
#55 WARNING(ORCAP-360
06): Part Name "FERRITEBEAD_2_HF70ACB201209_600MAFB10OHM" is renamed to "FERRITEBEAD_2_HF70ACB201209_600".
#56 WARNING(ORCAP-36006): Part Name "FERRITEBEAD_1_1206_HI1206N101R-10" is renamed to "FERRITEBEAD_1_1206_HI1206N101R-".
#57 WARNING(ORCAP-36006): Part Name "FERBEAD_8_SM-7351-IND-0805_150OHM800MA" is renamed to "FERBEAD_8_SM-7351-IND-0805_150O".
#58 WARNING(ORCAP-36006): Part Name "FERBEAD_9_SM-7351-IND-0805_150OHM800MA" is renamed to "FERBEAD_9_SM-7351-IND-0805_150O".
#59 WARNING(ORCAP-36006): Part Name "FERBEAD_10_SM-7351-IND-0805_150OHM800MA" is renamed to "FERBEAD_10_SM-7351-IND-0805_150".
#60 WARNING(ORCAP-36006): Part Name "FERBEAD_11_SM-7351-IND-0805_150OHM800MA" is renamed to "FERBEAD_11_SM-7351-IND-0805_150".
#61 WARNING(ORCAP-36006): Part Name "FERBEAD_12_SM-7351-IND-0805_150OHM800MA" is renamed to "FERBEAD_12_SM-7351-IND-0805_150".
#62 WARNING(ORCAP-36006): Part Name "FERBEAD_180OHM200MA_SM-7351-IND-0805_150OHM800MA" is renamed to "FERBEAD_180OHM200MA_SM-7351-IND".
#63 WARNING(ORCAP-3
6006): Part Name "CONN_MICROSD_8_SD-MICRO-SCHA5B0300_SCHA5B0200" is renamed to "CONN_MICROSD_8_SD-MICRO-SCHA5B0".
#64 WARNING(ORCAP-36006): Part Name "30 PIN CONNECTOR_0_30PINCONNECTOR_30PINCON" is renamed to "30 PIN CONNECTOR_0_30PINCONNECT".
#65 WARNING(ORCAP-36006): Part Name "HEADER10X2_CJTAG_HEADER10X2_CTI JTAG" is renamed to "HEADER10X2_CJTAG_HEADER10X2_CTI".
#66 WARNING(ORCAP-36042): Pin "GND" is renamed to "GND#8" as visible power pin of same name already exists in Package Header10x2_CJTAG , J2: TMDSSK3358-1V2A, Pg06: SDMMC, EEPROM, JTAG (9.20, 10.30).
#67 WARNING(ORCAP-36042): Pin "GND" is renamed to "GND#10" as visible power pin of same name already exists in Package Header10x2_CJTAG , J2: TMDSSK3358-1V2A, Pg06: SDMMC, EEPROM, JTAG (9.20, 10.30).
#68 WARNING(ORCAP-36042): Pin "GND" is renamed to "GND#12" as visible power pin of same name already exists in Package Header10x2_CJTAG , J2: TMDSSK3358-1V2A, Pg06: SDMMC, EEPROM, JTAG (9.20, 10.30).
#69 WARNING(ORCAP-36042): Pin "GND" is renamed to "
GND#16" as visible power pin of same name already exists in Package Header10x2_CJTAG , J2: TMDSSK3358-1V2A, Pg06: SDMMC, EEPROM, JTAG (9.20, 10.30).
#70 WARNING(ORCAP-36042): Pin "GND" is renamed to "GND#20" as visible power pin of same name already exists in Package Header10x2_CJTAG , J2: TMDSSK3358-1V2A, Pg06: SDMMC, EEPROM, JTAG (9.20, 10.30).
#71 WARNING(ORCAP-36006): Part Name "2.2UHINDUCTOR10%2_0.6ASMD_VLCF5020T_2.2UH" is renamed to "2.2UHINDUCTOR10%2_0.6ASMD_VLCF5".
#72 WARNING(ORCAP-36006): Part Name "2.2UHINDUCTOR10%2_1.6ASMD_VLCF5020T_2.2UH" is renamed to "2.2UHINDUCTOR10%2_1.6ASMD_VLCF5".
#73 WARNING(ORCAP-36006): Part Name "4.7UHINDUCTOR30%3_0.1ASMD_SMD_SLF7055T_33UH" is renamed to "4.7UHINDUCTOR30%3_0.1ASMD_SMD_S".
#74 WARNING(ORCAP-36006): Part Name "4.7UH30%0_1.9ASMD_MIPF2016_4.7UH" is renamed to "4.7UH30%0_1.9ASMD_MIPF2016_4.7U".
#75 WARNING(ORCAP-36006): Part Name "DLW5BTN501SQ2L_DLW5BTN501SQ2_DLW5BTN501SQ2L" is renamed to "DLW5BTN501SQ2L_DLW5BTN501SQ2_DL".
#76 WARNING(ORCAP-36006): Pa
rt Name "10KOHMRESISTOR1/16W0402_SM-7351-RES-0402_10K" is renamed to "10KOHMRESISTOR1/16W0402_SM-7351".
#77 WARNING(ORCAP-36006): Part Name "470KOHM1/16W1%SMD0402_SM-7351-RES-0402_470K" is renamed to "470KOHM1/16W1%SMD0402_SM-7351-R".
#78 WARNING(ORCAP-36006): Part Name "10KOHMRESISTOR1/16W0402_SM-7351-RES-0402_33.2K" is renamed to "10KOHMRESISTOR1/16W0402_SM-73_1".
#79 WARNING(ORCAP-36006): Part Name "150OHM1/16W1%SMD0402_SM-7351-RES-0402_150" is renamed to "150OHM1/16W1%SMD0402_SM-7351-RE".
#80 WARNING(ORCAP-36006): Part Name "4.75KOHMRESISTOR1/16W1%0402_SM-7351-RES-0402_4.75K, 1%" is renamed to "4.75KOHMRESISTOR1/16W1%0402_SM-".
#81 WARNING(ORCAP-36006): Part Name "ZEROOHMRESISTOR1/16W0402_SM-7351-RES-0402_0" is renamed to "ZEROOHMRESISTOR1/16W0402_SM-735".
#82 WARNING(ORCAP-36006): Part Name "100OHM1/16W1%SMD0402_SM-7351-RES-0402_100" is renamed to "100OHM1/16W1%SMD0402_SM-7351-RE".
#83 WARNING(ORCAP-36006): Part Name "ZEROOHMRESISTOR1/16W0402_SM-7351-RES-0402_DNI" is renamed to "ZEROOHMRESISTOR1/1
6W0402_SM-7_1".
#84 WARNING(
ORCAP-36006): Part Name "240OHMRESISTOR1/10W1%0402_SM-7351-RES-0402_240, 1%" is renamed to "240OHMRESISTOR1/10W1%0402_SM-73".
#85 WARNING(ORCAP-36006): Part Name "10KOHMRESISTOR1/10W1%0402_SM-7351-RES-0402_10K, 1%" is renamed to "10KOHMRESISTOR1/10W1%0402_SM-73".
#86 WARNING(ORCAP-36006): Part Name "33OHMRESISTOR1/16W5%0402_SM-7351-RES-0402_33" is renamed to "33OHMRESISTOR1/16W5%0402_SM-735".
#87 WARNING(ORCAP-36006): Part Name "100KOHMRESISTOR1/16W0402_SM-7351-RES-0402_100K" is renamed to "100KOHMRESISTOR1/16W0402_SM-735".
#88 WARNING(ORCAP-36006): Part Name "4.7KOHMRESISTOR1/16W0402_SM-7351-RES-0402_4.7K" is renamed to "4.7KOHMRESISTOR1/16W0402_SM-735".
#89 WARNING(ORCAP-36006): Part Name "0.24OHM0.25W1%SENSE0805_SM_RES_0805_KELV_0.24OHM1% SENSE" is renamed to "0.24OHM0.25W1%SENSE0805_SM_RES_".
#90 WARNING(ORCAP-36006): Part Name "22OHMRESISTOR1/16W1%0402_SM-7351-RES-0402_22" is renamed to "22OHMRESISTOR1/16W1%0402_SM-735".
#91 WARNING(ORCAP-36006): Part Name "100KOHMRESISTOR1/16W0402_SM-7351-RES-040
2_DNP" is renamed to "100KOHMRESISTOR1/16W0402_SM-7_1".
#92 WARNING(ORCAP-36006): Part Name "10KOHMRESISTOR1/16W0402_SM-7351-RES-0402_DNP" is renamed to "10KOHMRESISTOR1/16W0402_SM-73_2".
#93 WARNING(ORCAP-36006): Part Name "ZEROOHMRESISTOR1/16W0603_SM-7351-RES-0603_0" is renamed to "ZEROOHMRESISTOR1/16W0603_SM-735".
#94 WARNING(ORCAP-36006): Part Name "2.37KOHMRESISTOR1/16W1%0402_SM-7351-RES-0402_2.37K" is renamed to "2.37KOHMRESISTOR1/16W1%0402_SM-".
#95 WARNING(ORCAP-36006): Part Name "1KOHMRESISTOR1/16W0402_SM-7351-RES-0402_1K" is renamed to "1KOHMRESISTOR1/16W0402_SM-7351-".
#96 WARNING(ORCAP-36006): Part Name "22OHMRESISTOR1/16W1%0402_SM-7351-RES-0402_75" is renamed to "22OHMRESISTOR1/16W1%0402_SM-7_1".
#97 WARNING(ORCAP-36006): Part Name "33OHMRESISTOR1/16W5%0402_SM-7351-RES-0402_DNI" is renamed to "33OHMRESISTOR1/16W5%0402_SM-7_1".
#98 WARNING(ORCAP-36006): Part Name "10KOHMRESISTOR1/16W0402_SM-7351-RES-0402_DNI" is renamed to "10KOHMRESISTOR1/16W0402_SM-73_3".
#99 WARNING(ORCAP-36006): Part N
ame "49.9OHM1/3W1%SMDMELF0102_SMD_MELF0102_49.9" is renamed to "49.9OHM1/3W1%SMDMELF0102_SMD_ME".
#100 WARNING(ORCAP-36006): Part Name "1.2KOHMRESISTOR1/4W5%0805_SM-7351-RES-0805_20.5K, 1/8W" is renamed to "1.2KOHMRESISTOR1/4W5%0805_SM-73".
#101 WARNING(ORCAP-36006): Part Name "1MOHMRESISTOR1/16W0402_SM-7351-RES-0402_1M" is renamed to "1MOHMRESISTOR1/16W0402_SM-7351-".
#102 WARNING(ORCAP-36006): Part Name "1.2KOHMRESISTOR1/4W5%0805_SM-7351-RES-0805_63.4K, 1/8W" is renamed to "1.2KOHMRESISTOR1/4W5%0805_SM-_1".
#103 WARNING(ORCAP-36006): Part Name "1.2KOHMRESISTOR1/4W5%0805_SM-7351-RES-0805_1.0K, 1/8W, 1.0%" is renamed to "1.2KOHMRESISTOR1/4W5%0805_SM-_2".
#104 WARNING(ORCAP-36006): Part Name "1.2KOHMRESISTOR1/4W5%0805_SM-7351-RES-0805_3.09K, 1/8W, 1.0%" is renamed to "1.2KOHMRESISTOR1/4W5%0805_SM-_3".
#105 WARNING(ORCAP-36006): Part Name "0.1OHM0.33W1%SENSE0805_SM_RES_0805_KELV_0.1OHM1% SENSE" is renamed to "0.1OHM0.33W1%SENSE0805_SM_RES_0".
#106 WARNING(ORCAP-36006): Part Name "1.5KOHMRESISTOR1/16W5%SM
D0402_SM-7351-RES-0402_1.5K" is renamed to "1.5KOHMRESISTOR1/16W5%SMD0402_S".
#107 WARNING(ORCAP-36006): Part Name "220OHM1/10W1%SMD0402_SM-7351-RES-0402_220" is renamed to "220OHM1/10W1%SMD0402_SM-7351-RE".
#108 WARNING(ORCAP-36006): Part Name "10KOHMRESISTOR1/16W0402_SM-7351-RES-0402_64.9K" is renamed to "10KOHMRESISTOR1/16W0402_SM-73_4".
#109 WARNING(ORCAP-36006): Part Name "33OHMX8_1/16W5%SMD_SM_RPAK_EXB-2HV_33X8" is renamed to "33OHMX8_1/16W5%SMD_SM_RPAK_EXB-".
#110 WARNING(ORCAP-36006): Part Name "SWITCH_PUSHBUTTONSMD_SW_B3SL-1022P_DNI" is renamed to "SWITCH_PUSHBUTTONSMD_SW_B3SL-10".
#111 WARNING(ORCAP-36006): Part Name "SWITCH_PUSHBUTTONSMD_SW_B3SL-1022P_B3SL" is renamed to "SWITCH_PUSHBUTTONSMD_SW_B3SL-_1".
#112 WARNING(ORCAP-36006): Part Name "TESTPOINT_SMD1MMCIRCLE_TP_SMD1MMCIRCLE_TP1MM" is renamed to "TESTPOINT_SMD1MMCIRCLE_TP_SMD1M".
#113 WARNING(ORCAP-36006): Part Name "TESTPOINTTHROUGHHOLE_TH_TP_5002_TP" is renamed to "TESTPOINTTHROUGHHOLE_TH_TP_5002".
#114 WARNING(ORCAP-36006): Part Na
me "AM335X_4_BGA15X15-324-55M_
AM335X_ZCZ" is renamed to "AM335X_4_BGA15X15-324-55M_AM335".
#115 WARNING(ORCAP-36042): Pin "VSSA_USB" is renamed to "VSSA_USB#N14" as visible power pin of same name already exists in Package AM335X_4C , U1A: TMDSSK3358-1V2A, Pg02: AM335X Section 1 of 3 (6.30, 4.10).
#116 WARNING(ORCAP-36042): Pin "VSSA_USB" is renamed to "VSSA_USB#M14" as visible power pin of same name already exists in Package AM335X_4C , U1A: TMDSSK3358-1V2A, Pg02: AM335X Section 1 of 3 (6.30, 4.10).
#117 WARNING(ORCAP-36006): Part Name "TPS65910A3_4_U_48_RSL_TPS65910A3" is renamed to "TPS65910A3_4_U_48_RSL_TPS65910A".
#118 WARNING(ORCAP-36006): Part Name "TPS78633DCQ_SOT223_6PIN_TPS78633" is renamed to "TPS78633DCQ_SOT223_6PIN_TPS7863".
#119 WARNING(ORCAP-36042): Pin "GND" is renamed to "GND#6" as visible power pin of same name already exists in Package TPS78633DCQ , U12: TMDSSK3358-1V2A, Pg07: Platform_Power (15.30, 10.90).
#120 WARNING(ORCAP-36042): Pin "GND" is renamed to "GND#3" as visible power pin of same name already exists i
#121 WARNING(ORCAP-36006): Part Name "TPS71718_SOT23-5_P95_3X1P6X1P45_RT9013-12GB" is renamed to "TPS71718_SOT23-5_P95_3X1P6X1P45".
#122 WARNING(ORCAP-36006): Part Name "TPS71718_SOT23-5_P95_3X1P6X1P45_TLV70025DDC" is renamed to "TPS71718_SOT23-5_P95_3X1P6X1P_1".
#123 WARNING(ORCAP-36006): Part Name "AR8031-AL1A_QFN48_0_QFN48_AR8031_AL1A" is renamed to "AR8031-AL1A_QFN48_0_QFN48_AR803".
#124 WARNING(ORCAP-36006): Part Name "EP4CE10F17C8_TCC_11_256FBGA_EP4CE10F17C8_TCC" is renamed to "EP4CE10F17C8_TCC_11_256FBGA_EP4".
#125 WARNING(ORCAP-36006): Part Name "74LVC244A/SO_2_SOIC-20_74LVC244A/SO" is renamed to "74LVC244A/SO_2_SOIC-20_74LVC244".
#126 WARNING(ORCAP-36006): Part Name "MT41J128M16JT-125_BGA14X10-96_MT41J128M16JT-125:K" is renamed to "MT41J128M16JT-125_BGA14X10-96_M".
#127 WARNING(ORCAP-36006): Part Name "CRYSTAL24MHZ18PFSMD_0_XTAL4_3P2X2P5_SMD_24MHZ" is renamed to "CRYSTAL24MHZ18PFSMD_0_XTAL4_3P2".
#128 WARNING(O
RCAP-36006): Part Name "CRYSTAL_SMD32_2_MC-306_32.768KHZ MC-306" is renamed to "CRYSTAL_SMD32_2_MC-306_32.768KH".
#129 WARNING(ORCAP-36006): Part Name "CRYSTAL25MHZABM3_SM_OSC_ABM3_25MHZ" is renamed to "CRYSTAL25MHZABM3_SM_OSC_ABM3_25".
#130 WARNING(ORCAP-36006): Part Name "CRYSTAL24MHZ18PFSMD_0_XTAL4_1P6X1P2_SMD_20MHZ" is renamed to "CRYSTAL24MHZ18PFSMD_0_XTAL4_1P6".
INFO(ORCAP-36080): Scanning netlist files ...
Loading... C:\USERS\DARCY\DESKTOP\ORCAD TRAINING\TRAINING\TCC\allegro/pstchip.dat
Loading... C:\USERS\DARCY\DESKTOP\ORCAD TRAINING\TRAINING\TCC\allegro/pstxprt.dat
Loading... C:\USERS\DARCY\DESKTOP\ORCAD TRAINING\TRAINING\TCC\allegro/pstxnet.dat
packaging the design view...
Exiting... "C:\Cadence\SPB_17.2\tools\bin\pstswp.exe" -pst -d "C:\USERS\DARCY\DESKTOP\ORCAD TRAINING\TRAINING\TCC\TCC_0458-0000_REV2_SCH_14-12-02C.DSN" -n "C:\USERS\DARCY\DESKTOP\ORCAD TRAINING\TRAINING\TCC\allegro" -c "C:\Cadence\SPB_17.2\tools/capture/allegro.cfg" -v 3 -l 31 -s "" -j "PCB Footprint" -hpath "HPathForCollision" -lite
* Updating Allegro PCB Editor Board
INFO(ORCAP-32040): Updating Allegro PCB Editor Board
Spawning... netrev.exe -y 1 -z -i "C:\USERS\DARCY\DESKTOP\ORCAD TRAINING\TRAINING\TCC\allegro" "C:\Users\DARCY\Desktop\Orcad Training\training\TCC\pcb_0458-0000B.brd" "C:\USERS\DARCY\DESKTOP\ORCAD TRAINING\TRAINING\TCC\allegro\TCC2019.brd"
Reading File : C:/USERS/DARCY/DESKTOP/ORCAD TRAINING/TRAINING/TCC/allegro/pstchip.dat
(00:00:00.03)
Reading File : C:/USERS/DARCY/DESKTOP/ORCAD TRAINING/TRAINING/TCC/allegro/pstxprt.dat
(00:00:00.03)
Reading File : C:/USERS/DARCY/DESKTOP/ORCAD TRAINING/TRAINING/TCC/allegro/pstxnet.dat
(00:00:00.02)
Starting to process component instances
Finished component instance processing
Starting to check device models
Finished checking device models
Starting to process nets
Finished net processing
Starting to process slot properties
Finished slot property processing
Starting to process component instance properties
Finished component instance property processing
Performing a partial design check before saving.
Writing design to disk.
'TCC2019.brd' saved to disk.
netrev run on Jan 29 16:13:17 2019
DESIGN NAME : 'TCC_0458-0000_REV2_SCH_14-12-02C'
PACKAGING ON Mar 2 2016 00:37:24
No error detected
No oversight detected
1 warnings detected
cpu time 0:01:05
elapsed time 0:00:01
Exiting... netrev.exe -y 1 -z -i "C:\USERS\DARCY\DESKTOP\ORCAD TRAINING\TRAINING\TCC\allegro" "C:\Users\DARCY\Desktop\Orcad Training\training\TCC\pcb_0458-0000B.brd" "C:\USERS\DARCY\DESKTOP\ORCAD TRAINING\TRAINING\TCC\allegro\TCC2019.brd"
( Allegro Netrev Import Logic )
( Drawing : pcb_0458-0000B.brd )
( Software Version : 17.2P019 )
( Date/Time : Tue Jan 29 16:13:17 2019 )
------ Directives ------------
Ripup etch: No
Ripup delete first segment: No
Ripup retain bondwire: No
Ripup symbols: Always
Missing symbol has error: No
DRC update: Yes
Schematic directory: 'C:\USERS\DARCY\DESKTOP\ORCAD TRAINING\TRAINING\TCC\allegro'
Design Directory: '.'
Old design name: 'C:/Users/DARCY/Desktop/Orcad Training/training/TCC/pcb_0458-0000B.brd'
New design name: 'TCC2019.brd'
CmdLine: netrev.exe -y 1 -z -i C:\USERS\DARCY\DESKTOP\ORCAD TRAINING\TRAINING\TCC\allegro C:\Users\DARCY\Desktop\Orcad Training\training\TCC\pcb_0458-0000B.brd C:\USERS\DARCY\DESKTOP\ORCAD TRAINING\TRAINING\TCC\allegro\TCC2019.brd
------ Preparing to read pst files ------
Starting to read C:/USERS/DARCY/DESKTOP/ORCAD TRAINING/TRAINING/TCC/allegro/pstchip.dat
Finished reading C:/USERS/DARCY/DESKTOP/ORCAD TRAINING/TRAINING/TCC/allegro/pstchip.dat (00:00:00.03)
Starting to read C:/USERS/DARCY/DESKTOP/ORCAD TRAINING/TRAINING/TCC/allegro/pstxprt.dat
Finished reading C:/USERS/DARCY/DESKTOP/ORCAD TRAINING/TRAINING/TCC/allegro/pstxprt.dat (00:00:00.03)
Starting to read C:/USERS/DARCY/DESKTOP/ORCAD TRAINING/TRAINING/TCC/allegro/pstxnet.dat
Finished reading C:/USERS/DARCY/DESKTOP/ORCAD TRAINING/TRAINING/TCC/allegro/pstxnet.dat (00:00:00.02)
------ Oversights/Warnings/Errors ------
WARNING(SPMHNI-363): Signal model '33OHMRESISTOR1_16W5_0402_SM_735_33' not found; may effect xnets and electrical constraints.
#1 WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]
WARNING(SPMHNI-194): Symbol '30PINCONNECTOR' used by RefDes J12 for device '30 PIN CONNECTOR_0_30PINCONNECT' not found in PSMPATH or must be "dbdoctor"ed.
------ Library Paths ------
MODULEPATH = .
C:/Cadence/SPB_17.2/share/local/pcb/modules
PSMPATH = .
symbols
../symbols
C:/Cadence/SPB_17.2/share/local/pcb/symbols
C:/Cadence/SPB_17.2/share/pcb/pcb_lib/symbols
C:/Cadence/SPB_17.2/share/pcb/allegrolib/symbols
PADPATH = .
symbols
../symbols
C:/Cadence/SPB_17.2/share/local/pcb/padstacks
C:/Users/DARCY/Desktop/Orcad Training/training/Library/
------ Summary Statistics ------
COMPILE 'logic'
CHECK_PIN_NAMES OFF
CROSS_REFERENCE OFF
FEEDBACK OFF
INCREMENTAL OFF
INTERFACE_TYPE PHYSICAL
MAX_ERRORS 500
MERGE_MINIMUM 5
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
NET_NAME_LENGTH 24
OVERSIGHTS ON
REPLACE_CHECK OFF
SINGLE_NODE_NETS ON
SPLIT_MINIMUM 0
SUPPRESS 20
WARNINGS ON
No error detected
1 warnings detected
cpu time 0:01:05
  • steve
    steve over 6 years ago
    So these are just warnings and the netlist files are created, the warnings relate to the device name being renamed to match the device name limit you have set. There are also warnings about signal models not being found but unless you are doing SI analysis on the pcb this shouldn't be an issue. The actual issue you have to resolve is that the PCB Footprint called 30PINCONNECTOR is not found in your library paths. Make sure that the 30PINCONNECTOR.dra and 30PINCONNECTOR.psm are available in the psmpath location. If you need to configure this look at:orcad.co.uk/.../Defining_padpath_psmpath.pdf
  • StepscanDarcy
    StepscanDarcy over 6 years ago in reply to steve
    Thanks so much for the response Steve.   I'm going to try this out later today, and let you know how it went.
    -Darcy
  • StepscanDarcy
    Hey Steve,
    I believe I have successfully updated the paths based on the document you shared, but i'm getting the exact same error's still.
    INI File Location:C:\Users\DARCY\AppData\Roaming\SPB_Data\cdssetup\OrCAD_Capture/17.2.0/Capture.ini
    Netlist Directory:
    Configuration File:
    #24 WARNING(ORCAP
    5_SM-7351-CAP-".
    #47
    09_600".
    #63 WARNING(ORCAP-3
    6W0402_SM-7_1".
    #84 WARNING(
    #128 WARNING(O
    (00:00:00.03)
    (00:00:00.03)
    (00:00:00.02)
    netrev run on Jan 30 15:29:50 2019
    No error detected
    1 warnings detected
    cpu time 0:00:58
    ( Date/Time : Wed Jan 30 15:29:50 2019 )
    Ripup etch: No
    DRC update: Yes
    MODULEPATH = .
    PSMPATH = C:/Users/DARCY/Desktop/Orcad Training/training/30 Pin Connector/
    symbols
    ../symbols
    PADPATH = C:/Users/DARCY/Desktop/Orcad Training/training/30 Pin Connector/
    symbols
    ../symbols
    COMPILE 'logic'
    CHECK_PIN_NAMES OFF
    CROSS_REFERENCE OFF
    FEEDBACK OFF
    INCREMENTAL OFF
    MAX_ERRORS 500
    MERGE_MINIMUM 5
    NET_NAME_LENGTH 24
    OVERSIGHTS ON
    REPLACE_CHECK OFF
    SINGLE_NODE_NETS ON
    SPLIT_MINIMUM 0
    SUPPRESS 20
    WARNINGS ON
    No error detected
    1 warnings detected
    cpu time 0:00:58
    I'd be happy to try any other suggestions you might have?  I've noticed the recommendation on using "doctor db", but I opened it up, but don't understand how to use it in this case.
  • StepscanDarcy
    Hey Steve,
    I tried what you recommended, but it didn't seem to make a difference.   I can see in the file that was generated that the file paths are in fact changed, but the result is the same.   There is the recommendation to use doctor db, but I opened it, and am completely oblivious as to how to use it.
  • steve
    steve over 6 years ago in reply to StepscanDarcy
    Ok so you can either open the part in question that Netrev.lst mentions and then go to Tools - Database Check, click all the boxes and click on Check. Then save the part or if you have lots run DBDoctor as a standalone tool (like you have done), browse for a filename.dra in the psmpath location then edit the text from full_path_dir\filename.dra to full_path_dir\*.dra, leave the output name blank, check the boxes and click on check. This will uprev all your dra files. Repeat for psm, bsm, ssm, fsm, osm and pad.
