  3. Crossprobing between concept HDL & Allegro PCB Editor
  • Views 2180
Gowtham229
Gowtham229 over 6 years ago
Hi Anyone,
i'm using concept HDL for schematic & allegro for PCB design.i need to select multiple items using cross probe.But I can select only single component at a time in HDL for allegro.Can any one help me how to select multiple components in HDL so my work will be easy in PCB
  • CadAce2K
    CadAce2K over 6 years ago
    Whether you're selecting inside allegro or HDL - a) in allegro, use "temp grouping"; b) in HDL, make sure you have selectable elements correct and select the parts in a box, or with the 'ctrl' key held down. You can 'multi-select' pretty easy. You also need to run the project out of 'Project Manager' in case you hadn't considered that. Open the schematic, and the PCB design out of Project Manager.
