  3. Importing DXF file as board outline deletes everything ...
  • Views 2554
Importing DXF file as board outline deletes everything - 17.2
gborba
gborba over 7 years ago
I have imported a DFX file as my board outline per the procedure in the following post. After doing so,  the board outline appears to be updated, but everything else in the file disappears (title block, components, etc). I am using version 17.2. How can I only modify the outline layer and leave everything else unchanged?
https://community.cadence.com/cadence_technology_forums/f/pcb-design/14909/importing-dxf-into-allegro-16-2
  • Robert Finley
    Robert Finley over 7 years ago
    Yep, a dialog box is needed: "Are you sure you want to lose everything?"
    But, you need to always check [ ] Incremental Addition box on the right side of the import dialog before clicking [ IMPORT ]
  • gborba
    gborba over 7 years ago in reply to Robert Finley
    That worked - thank you!
