  3. How to create a template for a BOM in OrCAD Capture 17....
  • Views 14924
How to create a template for a BOM in OrCAD Capture 17.2
FormerMember
FormerMember over 6 years ago
I am using OrCAD Capture 17.2 H051.
I want to add some of the attributes to the BOM header and then set the same as default header. So whenever i open the tool for the next time i want the same header to appear for BOM generation
I do not want to add the attribute to BOM header each and every time for new projects (Refer the image )
Is there any solution available to this issue ?
Should I do some changes to capture.ini file for this issue ?
  • steve
    steve over 6 years ago
    OrCAD Capture CIS has this option which allows you to create report templates. In OrCAD Capture the only option you have is to copy these lines to a text file then paste into each new project.
  • UlfK
    UlfK over 6 years ago
    Once defined, I have found these liens in the .OPJ-file so just open one of them in a text editor and copy-paste.
