  3. OrCad PCB Editor 16.6, Artwork window do not show
  • Views 15831
Marciniak
Marciniak over 6 years ago
Hello everyone.
I am using software as in topic in version 16.6.
Today during normal work artwork button stopped working.
Window to set and generate artworks do not appear on the screen. I know that the button works, in the left down corner (actual command in written) I can see that ARTWORK command is active.
Is here someone who can help me?
I am using windows 10, I have tried to reinstall software and it do not help. All other functions and pop up windows work fine.
Thank in advance.
Piotr
  • steve
    steve over 6 years ago
    OK close the tools and open a Windows File Explorer window, in the address bar type %home% followed by a return. This opens your HOME folder, in here descend into the pcbenv folder and locate and delete the allegro.geo file. Restart the tools and try again.
    • Vote Up +2 Vote Down
  • steve
  • Marciniak
    Marciniak over 6 years ago in reply to steve
    Thank You Steve,
    Your solution worked.
