  3. Change component references and back annotation
  • Subscribers 166
  • Views 15738
Leotordo
Leotordo over 6 years ago
Hello.
I've a PCB (Orcad PCB) with connectors named: J1, J2, U3 (!), U4....schematic also have it.
I want to change ref. designator into CN1, CN2, CN3
If I do it from schematic side I found component unplaced.
Some idea?
Stefano
  • Robert Finley
    Robert Finley over 6 years ago
    The majority of pcb layout tools do this by design.
    An option is to export placement as an EMN/IDF file, make the schematic-driven refdes change, change these desigs in the EMN file, import back into layout after the schematic change.
  • redwire
    redwire over 6 years ago
    Simple.  Just edit the text of the reference designator in OrCad PCB and then backannotate to OrCAD schematic.  If you forward annotate from OrCAD schematic you will run exactly into the problem you have seen.
  • Leotordo
    Leotordo over 6 years ago in reply to redwire
    thank you very much
    Stefano
  • Leotordo
    just tried. it works
    thank you
    Stefano
  • Robert Finley
    Robert Finley over 6 years ago in reply to redwire
    Had no idea we could do that.   Thanks!
