  3. Orcad Capture 17.2 Footprint Viewer not working
  • Subscribers 166
  • Views 15964
Velocityidp
Velocityidp over 6 years ago
Yes, I've made sure that the included paths in Capture.ini are correct. Yes I selected the correct ini (used to one printed out in the session log field at Capture startup). Yes, I've even tested a footprint known to work in PCB Editor (EMC0402) but it fails to show up in Capture when I click "Show Footprint"
I get the following message in the Show Footprint screen:
"Could not launch footprint, see Capture session log for more details."
Then when I look in the session log, it says:
"Parrent Schematic Occurence is NULL"
Yes, those spelling errors are not my typos, its a direct copy-paste from the log. I tried to google that specific error message and I get zero results. I have no idea what the issue is. Any ideas? Because I'm at a loss.
  • W2fdr64
    W2fdr64 over 4 years ago
    Hi Velocity
    I have the same issue. Did you solve ?
    where can I found the session log file ?
    Tks
    Franco
