  3. Adding chessboard-style named pins
  • Views 13250
jweidenauer
jweidenauer over 6 years ago
Hi All,
is there a way to add a "matrix" of pins, as needed for BGA packages,
where the Pins are named in a chessboard, like the following?
A0, A1, A2, A3, A4, ...
B0, B1, B2, B3, B4, ...
C0, C1, C2, C3, C4, ...
Also: Is there a way to increment in a hexadecimal way, like A0, A1, A2, ..., A8, A9, AA, AB, AC ?
Thank you very much!
Best regards
Janis Weidenauer
  • steve
    steve over 6 years ago
    You can either use the BGA wizard when making the footprint or add the pins using the Copy mode (Layout - Pins) command and label them 1-XXXX. Once you have the pins use Layout - Renumber pins and pick the style you want.
  • jweidenauer
    jweidenauer over 6 years ago in reply to steve
    Thank you!
  • jweidenauer
    Thank you!
