  3. mvia to thruvia DRC missing
  • Views 13756
redwire
redwire over 6 years ago
Hi
I am having difficulty getting a DRC to occur when I stack a microvia on top of a thru via.  If the mvia is not stacked then the DRC is getting flagged if it's on the edge of the thru via.
However, when the mvia is coincident with the thru via the DRC goes away.
I *think* I have the DRC setup correct for Same Net checking but am puzzled as to why the overlap is allowed.
Any hints on how to flag overlap of thru to mvia?
  • steve
    steve over 6 years ago
    Have a look at orcad.co.uk/.../Microvia_Overview.pdf. Page 11 describes the rules required for inset vias.
  • steve
  • redwire
    redwire over 6 years ago in reply to steve
    Hi Steve -- thanks for the link but still no solution.  The missing error only happens when a microvia sits on a thru via.  The slightest offset triggers the DRC but I need to find out how to get the overlap DRC to show up as well.
    Thanks.
  • steve
    steve over 6 years ago in reply to redwire
    What about the pad-pad connect options? There is also a via in pad rule that may show DRC's if they are not coincident. orcad.co.uk/.../via_in_pad_rules.pdf
