  3. radius change on dynamic shape arc
  • Replies 8
  • Subscribers 166
  • Views 17542
masamasa
masamasa over 6 years ago
hello
Is there any way that i can change the radius of the arc on dynamic shapes?
If so, can you tell me how?
  • masamasa
    masamasa over 5 years ago in reply to excellon1
    thank you for your reply.
    i am sorry that i did not make it clear enough
    this is not what i am asking actually
    i do know how to change any corners rounded all at once with the tab key automatically without boundary edit.
    the corners i am questioning about are created by a notch over the shape because of a cline with a different net as shown below.
    do you know how to change them a rounded corner?
  • steve
    steve over 5 years ago in reply to masamasa
    These are related to the voided part of the shape. You can control this but it may have side effects. Look at Shape - Global Dynamic Parameters (or right click just the shape in question and select Parameters) then Void Controls tab and for acute angle trim control - set this to full round. This will round the corners, you can then adjust the radius using min aperture for gap width. This may be best done on a shape by shape basis rather than on all shapes.
  • masamasa
    masamasa over 5 years ago in reply to steve
    thank you steve
    i was able to change the corners.
    i did not use the global dynamic parameters as i set different parameters for each layer.
    instead i used dynamic shape instance parameters for each shape.
    thank you again.
