  3. Setting DC impedance for nets
  • Replies 7
  • Subscribers 163
  • Views 17758
Mysil B
Mysil B over 7 years ago
We do quite a lot of designs where we use the trace resistance to balance diodes in parallel for DC currents. Is there any way we can set the a impedance constraint for this so we can control the lengths automatically? Since we vary the width on these traces and mix them with copper polygons, we cannot simply set a track length constraint... We'd need to have a constraint on total resistance from end to end on a single net.
Best regards, Mysil
  • DavidJHutchins
    DavidJHutchins over 7 years ago
    There are a couple of different ways of accessing a property such as that, first is the property definition:
    skill 'axlDBCreatePropDictEntry("net_resistance" "resistance" list("nets"))'
    below is a simple function that scans all the design for that property & prints it's name & value:
    procedure(net_res_test()
    foreach( net axlDBGetDesign()->nets
    when(net->prop->NET_RESISTANCE
    axlMsgPut("net %s NET_RESISTANCE %s" net->name net->prop->NET_RESISTANCE)
    below is an example of running it:
    Command > skill net_res_test
    net PWRBRK_N_NC NET_RESISTANCE 0.123 Ohm
    (dbid:372454688 dbid:372454632 dbid:372454576 dbid:372454520 dbid:372454464 dbid:372454408 dbid:372454352 dbid:372454296 dbid:372454240 dbid:372454184 dbid:372343864 dbid:372343808 dbid:372343752
  • Mysil B
    Mysil B over 7 years ago in reply to DavidJHutchins
    Thank you very much, David! I shall try it out. There is no way of autorouting nets using SKILL scripts?
  • Mysil B
