  3. Highlight all Untested nets simultaneously?
  • Views 14100
LouShay
LouShay over 6 years ago
Hi All, Does anyone have a method to highlight all Untested nets simultaneously?  I’ve generated automatic testpoints. Now I simply want to see a board view (zoom fit) of the remaining untested nets. I can’t seem to put a Find by Query together that satisfies my requisite. Fyi: I’m aware of the manual (Scan and highlight) function. Thanks for your help/suggestions.
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    below is the skill code that generates a testprep report, then reads it & highlights the nets that are not tested...
    procedure(highlite_notest()
    let((rptFile cnt inport line flag list list2)
    (rptFile = "test_report.txt")
    axlShell("reports \"Testprep Report\" nographic write test_report.txt")
    axlMsgPut("reading %s" rptFile)
    (cnt = 0)
    (flag = nil)
    (inport = infile(rptFile))
    when(inport
    while(gets(line inport)
    when(and(not(nindex(line "---")) not(nindex(line "===")))
    when(flag
    (list=parseString(line "|"))
    when(eq(length(list) 3)
    (list2 = parseString(car(list)))
    when(eq(length(list2) 1)
    axlClearSelSet()
    axlSelectByName("NET" car(list2))
    (axlHighlightObject axlGetSelSet() t)
    cnt++
    when(nindex(line "Nets currently not tested")
    (flag = t)
    when(nindex(line "Total number of nets not currently tested")
    (flag = nil)
    close(inport)
    axlMsgPut("%d nets highlighted" cnt)
    axlCmdRegister( "highlite_notest" 'highlite_notest)
    Below is the transcript from in Allegro:
    Command > skill 'load("c:/users/davidh/documents/highlite_notest.il")'
    t
    Command > highlite_notest
    Loading axlcore.cxt
    reading test_report.txt
    45 nets highlighted
    Command >
  • LouShay
    LouShay over 6 years ago in reply to DavidJHutchins
    Hey Thanks David, I didn't get a chance to give it a go today, but will try Monday. I'm sure it will work well. Thanks so much.
  • LouShay
    The skill code routine provided exactly what I was looking for.  Thanks again David!
  • JFuoco
    JFuoco over 6 years ago in reply to DavidJHutchins
    This worked perfectly, what a great script to have, thanks DavidJHutchins
