  3. OrCad PCB Editor File Extensions - a definitive list *please...
  • Subscribers 167
  • Views 19321
OrCad PCB Editor File Extensions - a definitive list *please*
ElectroMan
ElectroMan over 6 years ago
In the process of creating footprints, board layouts, format symbols and the like, OrCAD PCB editor creates a plethora of files and some sub-folders.
We have a repository and want to save out ONLY the files we NEED to save instead of this maelstrom of files and folders.
I have been looking for a definitive list of file extensions used by or generated by OrCAD PCB editor so that I can determine exactly which files we MUST save and which may be discarded.
e.g. A PCB footprint requires a *.DRA and a *.PSM file. All other files may be discarded.
Can anyone help me with such a list?
  • steve
    steve over 6 years ago
    .brd - board file
    .mdd - place replicate module file
    .dra and .psm - package symbol
    .dra and .bsm - Mechanical symbol
    .dra and .osm - format symbol
    .dra and ssm - shape symbol.
    .dra and fsm - flash symbol.
    .pad - padstack.
    pstxchip.dat, pstxnet.dat and pstxprt.dat (and if you use constraint manager in the front end pstdedb.cdsz) - netlist files.
    .dsn - schematic file.
    .opj - schematic project file but can be re-created so you may not need this.
    .olb - schematic library file.
  • ElectroMan
    ElectroMan over 6 years ago in reply to steve
    Fantastic!  Some of these I figured. Some were a surprise..
  • Mysil B
    Mysil B over 6 years ago
    On the same topic - is there any way to configure OrCAD PCB and Capture to store all auto generated files in a sub directory?
  • steve
    steve over 6 years ago in reply to Mysil B
    For PCB Look at Setup - User Preferences - File_management - output_dir. For Capture you can drive the netlist file location (when you create the netlist, the same for BOM genertaion and DRC checking but this is a manual browse for a location before you generate.
  • Mysil B
    Mysil B over 6 years ago in reply to steve
    All right, those files are already sorted, and by editing the User Preferences we can keep many of the config files in a single shared folder on our server.
    There seems to be a lot of autosave files left, and some other various files:
    For the autosave files, I'm trying to set the name as follows, crossing my fingers:
    How can we structure OrCAD to store the various other files into sub directories?
