  3. converting a text into a polyline on dxf export
  • Replies 8
  • Subscribers 163
  • Views 20284
masamasa
masamasa over 7 years ago
hello
is there any way i can convert a text to a polyline when exporting a design file as a dxf file?
  • DavidJHutchins
    DavidJHutchins over 7 years ago
    I don't think there is any easy way to do that with the Allegro toolset
    I attempted to output text in a stream file ( gds2 format ), but the text handling of that interface is worse than the dxf interface
  • masamasa
    masamasa over 7 years ago in reply to DavidJHutchins
    thank you for your response.
    is there any way to convert a text into a line or a shape within allegro?
  • eDave
    eDave over 7 years ago in reply to masamasa
    The Skill command axlText2Lines will help you do this.
  • masamasa
    masamasa over 7 years ago in reply to eDave
    i am quite new on allegro so i still do not know how to work on skill.
    do i need to create a program using axltext2lines?
  • DavidJHutchins
    Thanks to eDave for pointing out the use of that skill function, below is a transcript of using the example from the documentation:
    Command > skill
    last pick: 2767.00 3258.00
    Skill > (load "d:/cadence/spb_16.6/share/pcb/examples/skill/ash-fxf/ashone.il")
    t
    Skill > text = ashOne("TEXT")
    Enter selection point
    Loading axlcore.cxt
    last pick: 2792.00 3200.00
    dbid:300809880
    Skill > text->??
    (prop nil bBox
    ((2764.0 2785.0)
    (2870.0 3303.0)
    ) readOnly
    t objType "text" layer "ETCH/BOTTOM"
    xy
    (2842.0 3300.0) text "EXAMPLE" textBlock
    "19" rotation 90.0 parent nil
    mirrorType "YES" isMirrored t justify
    "LEFT" parentGroups nil
    Skill > lines = axlText2Lines(text)
    ((_axlPath@0x124d1098 _axlPath@0x124d1068)
    (_axlPath@0x124d10f8 _axlPath@0x124d10c8)
    (_axlPath@0x124d1168 _axlPath@0x124d1138)
    (_axlPath@0x124d11c8)
    (_axlPath@0x124d1278)
    (_axlPath@0x124d12b8)
    (_axlPath@0x124d1338 _axlPath@0x124d1308)
    Skill > (layer="ETCH/BOTTOM")
    "ETCH/BOTTOM"
    Skill > flattened = foreach( mapcan x lines x)
    (_axlPath@0x124d1098 _axlPath@0x124d1068 _axlPath@0x124d10f8 _axlPath@0x124d10c8 _axlPath@0x124d1168
    _axlPath@0x124d1138 _axlPath@0x124d11c8 _axlPath@0x124d1278 _axlPath@0x124d12b8 _axlPath@0x124d1338
    _axlPath@0x124d1308
    Skill > foreach(path flattened polys = axlPolyFromDB(path ?endCapType 'ROUND ?line2poly t) foreach(poly polys i = axlDBCreateShape(poly t layer nil nil)) )
    _axlPath@0x124d1308
    I then used the shape>merge shapes to combine the shapes that compose each character together to reduce the drc count
