  3. Impedance Probe?
  • Views 13133
Impedance Probe?
archive over 18 years ago
Hello, All.
I'm looking for a solution that is able to measure Input Impedance.
In SigXp, I can use Current Probe.
Like that, I want to know the Input Impedance on a node.
Is this possible?
Thanks in advance,
Best Regards,
YS Shin.
Originally posted in cdnusers.org by YSShin
    If you use Allegro PCB SI 630 or GXL as it is now called, you can generate the S parameters at any node. Alternatively, you can create an IBIS TDR as discussed in one of the articles here.
    Originally posted in cdnusers.org by Kalevi2
