  3. Setting up Constraint Manager to detect unwanted stubs
  • Views 13331
adomino
adomino over 6 years ago
My PCB Design had two floating vias and traces. This error was not detected in a DRC check, but with a netlist check from the ab house.
How can I set up the CM so that the DRC check will catch this floating via and trace/stub and unintentional antenna error?
Amy
  • Wild
    Wild over 6 years ago
    The Dangling Lines, Vias and Antenna Report should catch these.
