  3. Cannot add dummy net on No Connection pin
  • Subscribers 166
  • Views 15949
Dinesh K
Dinesh K over 6 years ago
I need to put Dummy net on NC pin of a LED. But when i put Dummy net and try to assign to that pin it is showing "cannot assign dummy net to that pin".
I need to put dummy net on that pin for heat dissipation.
Thanks & Regards,
K.Dinesh
  • Sutha
    Sutha over 6 years ago
    hi, dinesh
                   Actually it is possible you mentioned above that?
  • redwire
    redwire over 6 years ago
    You don't need to put "Dummy" net on the pin.  All unassigned pins get an internal definition of "Dummy" automatically.  You can always click and route from a pin or connect with a shape.  Just will have a DRC that needs to be waived.
  • Wild
    Wild over 6 years ago
    What I do (16.6) is add a short net to a pin in the schematic.  Then in the constraint manager I create a dummy CSet and create net properties such as spacing.  Once the CSet is created i assign the short net to the Cset.
    I do this alot for electric spacing on pins attached to packages that are design as a non bonded (internally) pins that are designed such to meet electrical clearances between to high voltage pins.  This way I don't have to wave DRC's (I don't like any DRC's even waved ones).
  • redwire
    redwire over 6 years ago in reply to Wild
    That's actually the best way IMHO to do it -- as you point out you can class these nets appropriately.
  • Dinesh K
    Dinesh K over 6 years ago in reply to redwire
    I did it. But still it is not getting connected. I am sharing the screen shot below for your reference.
