  3. utility to view the cross-probe messages between orcad capture...
  • Views 14623
utility to view the cross-probe messages between orcad capture and allegro pcb editor.
johnthanchau
johnthanchau over 6 years ago
there is no need to import logic from orcad in order to be able to cross probe with allegro.
  • RFinley
    RFinley over 6 years ago
    It depends.
    When I translate layouts from other layout software to Cadence, have to apply the CIS netlist to set the partname property the official Allegro way.
    Then, I can update all footprints to get the step models, place and DFA boundaries as it's pointless to capture that for PADS.
    With EMA-EDA's Circuitspace plugin, you skip all that as it allows you to crossprobe from (non-CIS) intelligent PDFs (DxDesigner)...
  • johnthanchau
    johnthanchau over 6 years ago in reply to RFinley
    i wish i can read out messages ping-ponging between orcad capture and allegro pcb editor.
    sometimes, some parts are able to cross probe. while others can not.
    just curious what the protocol looks like.
  • johnthanchau
  • RFinley
    RFinley over 6 years ago in reply to johnthanchau
    Any chance you would have non-ASCII characters in your schematic data(net names, part names, pin names?)  Unicode characters may not work still.
  • johnthanchau
    sometimes it is not ok, but after a while, all is well. so not sure what could be the problem.
