  3. how can sure a package have multiple parts in orcad capture...
  • Views 14622
how can sure a package have multiple parts in orcad capture ?
tennywhy
tennywhy over 6 years ago
which function could get the section number of a package have multiple parts in orcad cupture ?
i look out of the manual there have a  IsMultiPkg(), but it doesnt work however i try.
someone could teach me ? thanks
  • johnthanchau
    johnthanchau over 6 years ago
    IsMultiSectionPart ?
  • tennywhy
    tennywhy over 6 years ago in reply to johnthanchau
    thanks sir, what's the functions for move part reference to another place ?
  • tennywhy
  • johnthanchau
    johnthanchau over 6 years ago in reply to tennywhy
    if you mean text of display prop, part reference is one of that, you can select it, use Move command.
    copy&paste the following in command window, then try move one, it will show you how it is done.
    SetOptionBool Journaling TRUE
    SetOptionBool DisplayCommands TRUE
  • tennywhy
    not that, i need a function that move the reference to first pin and value to the second pin for all two pins parts include rotated and un-rotated. i meet two problems when i handle rotated parts , 1, i cant found a funtion for move reference, the move command can used page view mode only, 2, i cant location the pin coordinate, because the pin coordination i got by location functions was the coordinations pin in part edite mode, not the coordination pin page.  could you give me some advice ?
