  3. ERROR(ORCAP-32007): Netrev failed -- only when design is...
  • Views 4935
ERROR(ORCAP-32007): Netrev failed -- only when design is on Google File Stream drive
bowerymarc
bowerymarc over 6 years ago
Anyone else run into this and have a solution?
I have an orcad sch on a google filestream drive, and trying to create netlist and update board file:
(note the output directory also on google filestream)
I get:
Digging in the logfile, there are two places where files fail to write:
Performing a partial design check before saving.
Failed to open file 'G:/MY DRIVE/10-REV001/allegro/#Taaaaac30420.tmp'.
netrev run on May 17 10:34:12 2019
DESIGN NAME : 'REV001'
PACKAGING ON Feb 15 2016 19:53:59
2 errors detected
No oversight detected
No warning detected
cpu time 0:32:06
elapsed time 0:00:19
File save problem: The requested operation cannot be performed on a file with a user-mapped section open.
--- and then later ----
------ Oversights/Warnings/Errors ------
#1 ERROR(SPMHNI-235): Error detected saving design.
ERROR(SPMHNI-234): Cannot write drawing, 'G:/MY DRIVE/10-REV001/allegro/REV001.brd' out to the directory: 'Error while saving the drawing.'.
#2 Run stopped because errors were detected
When I copy the whole thing to a directory in my 'Documents' directory (on C: as usual) then the whole thing works with no errors.
So my two theories are that
1) non-NTFS file system somehow screws it up
2) non C: directory somehow screws it up
3) what's really going on (of which I have no idea!)
The right answer is probably 3 ;)
  • oldmouldy
    oldmouldy over 6 years ago
    You don't mention anything about which version of the tools you are using but, I would say, the first thing to do is change the mapping point for the drive to remove the space from the folder name, as in, G:\My Drive isn't going to work but G:\My_Drive (for example) likely would. This has certainly been an issue in older versions of the tools. I don't think that 1) and 2) are likely to be factors if Windows can read / write the target location for the files.
  • jc teyssier
    jc teyssier over 6 years ago in reply to oldmouldy
    I agree with oldmouldy: space in folder or file names have to be avoided.
    Such as @ , é, &, µ and so on...
  • bowerymarc
    bowerymarc over 6 years ago in reply to oldmouldy
    Sorry for not mentioning, version 16.6.  And, I have shortened the names to protect my client, but there were spaces in the file names in both the drive stream and non-drive stream version.  So that's not it, I thought the same thing at first.  Also, windows 10, totally updated, english version, no language packs.  No strange characters in the path names.   I should also mention, for those who don't know, that when you copy a file from NTFS to DriveStream you'll often (and in the case of the .brd file) get a warning that 'properties of the file won't be copied'.  Could be part of the issue?
