  3. How to check total thermal reliel on thru pin holes
  • Views 13103
jc teyssier
jc teyssier over 6 years ago
Hello group,
i am requested to insure that the total thermal relief copper cumulate on all layers will not be greater than a value.
This would be for soldering purpose, to avoid "cold" holes
Any advice how to adress this?
Jean-Charles
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    Below is an example skill function that will report the total 'thermal' widths for each through-hole pin in the design, I'm not sure what the best way to handle 'full-contact' pins are however...
    procedure(Get_ThmtThermalWidths()
    let((total connections)
    (total=0.0)
    foreach( comp axlDBGetDesign()->components
    when( comp->symbol
    foreach( pin comp->pins
    when(and(pin->definition pin->isThrough)
    (total=0.0)
    connections=axlDBGetConnect(pin t)
    foreach(con connections
    when(con->thermal
    foreach(seg con->segments
    (total=plus(total seg->width))
    (axlMsgPut "pin %s.%s x %g y %g total_width %f"
    comp->name pin->number
    (xCoord (pin->xy)) (yCoord (pin->xy))
    total
    axlCmdRegister( "get_thmtthermWidths" 'Get_ThmtThermalWidths ?cmdType "general")
    Below is an example of the output:
    \t (00:15:03) pin J3.26 x 191.95 y 2340.09 total_width 64.000000
    \t (00:15:03) pin J3.25 x -201.75 y 2340.09 total_width 120.000000
    \t (00:15:03) pin J3.24 x -288.36 y 2340.09 total_width 144.000000
    \t (00:15:03) pin J3.23 x -595.45 y 2340.09 total_width 160.000000
  • jc teyssier
    jc teyssier over 5 years ago in reply to DavidJHutchins
    I use this and it woks fine for me. Thank you (5 month...)
