  3. Local Library Creation
  • Replies 10
  • Subscribers 166
  • Views 18476
TIDVEng
TIDVEng over 6 years ago
I have a couple of questions:
1)    How can I create a local library in Cadence? Can you please send instructions on how to accomplish this?
2)    Once I have created said local library, how can I export this to other people in my group?
Thank you for your time
  • StephenH
    StephenH over 6 years ago
    Cadence is a company, not a software product :).
    Which tool are you using?
  • TIDVEng
    TIDVEng over 6 years ago in reply to StephenH
    I am using Cadence. Allegro Cadence allows component libraries.
  • StephenH
    StephenH over 6 years ago in reply to TIDVEng
    OK, so I've moved your post to the PCB design group where you're more likely to get an answer, you had posted to the functional verification group, which is not related to Allegro users.
  • CadAce2K
    CadAce2K over 6 years ago
    Under Setup/User Preferences/Paths there's a preference for 'Library'.
    In there, under PADPATH and PSMPATH you can set those for your 'local' library.
    Mine normally starts with a '.' (Dot); for a library at the .brd (design) folder.
    Next I have a ./symbols (for a library under the 'symbols' folder at the project level. This is normally where I'd store both my footprint symbols and the padstacks, specific for that design.
    Be aware - these are based on priority: with '.' being first, ./symbols being 2nd and the rest of the libraries after those. That way when I do a refresh (if I change a part locally), it will refresh from 'my' folders first.
    Good day.
  • TIDVEng
    TIDVEng over 6 years ago in reply to CadAce2K
    I am using Allegro, (Cadence ADW). I do not see the first button for setup/user preferences/paths... can you please provide a screenshot?
