  3. creating layer views in artwork control form
  • Subscribers 166
  • Views 15124
Lock2002
Lock2002 over 6 years ago
For what feels like 100 years I've been creating drawings, temporary views, dxf exports, etc. using the artwork control form. I've always exported gerbers manually and never had any issues. We want to transition to ODB++ (I know, late to the party). Anyway, I don't want my drawings or other junk included in the ODB++ export so they can't be in the control form as a film. I am aware of color views, but I don't like the idea of dragging around a bunch of text files with my .brd. There has to be a better way. If not Cadence needs to fix it.
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    Cadence added the film domain functionality in 16.6, which allows output selection for artwork, ipc2581, pdf & visiblity control
    The skill code supplied with the ODB++ Inside has never been updated to support this, so it outputs all artwork film records
    I have modified my local copy of that skill code & am attempting to get it back to the developers at Valor/Mentor...
  • steve
    steve over 6 years ago
    There is a user preference for this, Setup - User Preferences - Paths - Config - Viewpath, set this to a network location and put all your color view files here, they will then be available for all designs.
  • CadAce2K
    CadAce2K over 6 years ago
    I have a good number of 'additional reference layers/views' in my artwork control form, and don't have problems with ODB++. I've been using ODB++ for 6-8 years now, and no questions. The only one that gets confused is the engineer that mistakenly turns on all layers, and asks me to delete what's not necessary. I shoo them away.  :)  Good day.
  • DavidJHutchins
    DavidJHutchins over 6 years ago in reply to DavidJHutchins
    I sent the attached skill file to  odbinside@mentor.com, but who knows how long it will take for them to release a new version
  • CadAce2K
    CadAce2K over 6 years ago in reply to DavidJHutchins
    You might be a little better off sending it to Cadence. Mentor (odbinside@mentor.com) probably won't respond.  Slight smile
    Good day.
