  3. Database configuration not possible after new installat...
  • Replies 9
  • Views 19006
Database configuration not possible after new installation
Giatzo
Giatzo over 6 years ago
I'm moving to a new PC and I'm reconfiguring Orcad Capture CIS 17.2.  I don't know why, but I can't configure my database because I don't have the option in Options -> CIS Configuration. Why? 64bit Database is configured correctly.
  • oldmouldy
    oldmouldy over 6 years ago
    Open a Project, or Design, then you will see the option for CIS Configuration.
  • Giatzo
    Giatzo over 6 years ago in reply to oldmouldy
    I did it. The screenshot attached is taken with a project open. Here is another screenshot:
  • oldmouldy
    oldmouldy over 6 years ago in reply to Giatzo
    I guess that you have a valid license for Capture CIS 17.2 so, check the exact version that you are running, from Help>About in Capture. Latest version is 17.2-2016.s056
  • Giatzo
    Of course I have a valid license. Is it mandatory to have the latest version? In the old PC, Capture is not updated but I don't have this problem. My version is: 17.2-2016-P010
  • oldmouldy
    It's no mandatory to be running the latest version but, of course, updates will change the product and how it works. If you are running 17.2-2016.p010 on both machines, you could try starting Capture with the Run as Administrator option from the right-click menu on the shortcut, that might help to get the CIS software components registered. Before you get to any serious work though, I would recommend updating your Capture CIS installation, ideally, to the latest version, but, certainly, "something" later than the Base Release from April 2016.
