  3. (OrCAD/Allegro) Capture: Adding an extra hetergonenous part...
  • Subscribers 166
  • Views 3449
(OrCAD/Allegro) Capture: Adding an extra hetergonenous part to a homogenous multipart package - Can it be done?
UlfK
UlfK over 6 years ago
Having created a part consisting of 6 inverter gates as a homogenous multi part package with the individual gates -A, -B, -C (etc) and NOT wanting to hide the power pins I wanted to create a 7th "power" part (Vcc, GND). It seems that the only way to do this is to create a heterogenous part from the beginning and thus having to exactly re creating all the six gates graphics one by one.
Is there any "easy" way to accomplish this ?
  • oldmouldy
    oldmouldy over 6 years ago
    You can only change the type of a multi-part package on creation, it cannot be converted. What you can do is, start a new Heterogeneous Part, copy the graphics from the Homogeneous Part and paste the graphics into the required section(s). You then need to work on the Pin Numbers and the "last" part of the package.
  • UlfK
    UlfK over 6 years ago in reply to oldmouldy
    I think I tried that a long time ago but the copy-paste buffer did not work when "view-next-part" but I will give it a try with HF 056.
  • Learnorcad
    Learnorcad over 6 years ago
    You can get your instant solution from here....... https://learnorcadonline.com/orcad-and-allegro-pcb-design-tutorial-pdf-16-6/
    • Vote Up -2 Vote Down
  • oldmouldy
    oldmouldy over 6 years ago in reply to UlfK
    Copy / Paste in the Part and Symbol Editor has been part of the Capture training course material on Heterogeneous parts "forever" and has always worked when I have used it.
  • UlfK
    Tried it again and (of course) - it worked.
