  3. How to color the message print from SKILL to CMD window
  • Views 14864
Duc Nguyen SV
Duc Nguyen SV over 6 years ago
Hi ,
good day
I'm writing a SKILL
I'm looking a way to color the message print from SKILL to CMD window  (similar as what WARNING and ERROR message)?
The purpose for this is to highlight some important info to user.
Thanks in advance
  • B Bruekers
    B Bruekers over 6 years ago
    This only works with the new command line history option enabled (which you show).
    Use this format:
    axlMsgPut('("this is red %s" 3) "msg")
    axlMsgPut('("this is yellow %s" 2) "msg")
    The "msg' part you can use as input for the formatted string.
    Bram
  • B Bruekers
    Use this format:
    Bram
  • Duc Nguyen SV
    Duc Nguyen SV over 6 years ago in reply to B Bruekers
    Thank  B Bruekers so much, is there any others color ? I don't want it to duplicate the system notification color
  • B Bruekers
    B Bruekers over 6 years ago in reply to Duc Nguyen SV
    Something like this also works: axlMsgPut("<font color=LightCoral>Test</font>")
    So basically you can use HTML formatting...
  • Duc Nguyen SV
    Thank B Bruekers so much. it works ! ^^
