  3. Dynamic Phase not being checked
  • Views 15678
JoelMcW
JoelMcW over 6 years ago
I am using 16.6 and have the  diff pairs correctly assigned. I have constraints set up for the Dynamic Phase tolerance for both the Max Length and the tolerance. The tool however doesn't appear to actually be doing the checking. If I load the db in 17.2, the error shows up in the constraint manager. It doesn't show up in 16.6. Does Dynamic Phase not work in 16.6?
  • steve
    steve over 6 years ago
    Depends on the version of software you are running. When Dynamic Phase was introduced initially at 16.6 you would have needed Allegro PCB Designer + High Speed license. Now it is available in OrCAD PCB Professional 17.2 so what level of tools do you have?
  • JoelMcW
    JoelMcW over 6 years ago in reply to steve
    16.6 with the high speed and miniturization.
  • steve
    steve over 6 years ago in reply to JoelMcW
    OK so the license is good enough to be able to run this. What exact version of 16.6 ae you running? If it's 16.6 pXXX then get the latest hotfix from http://support.cadence.com and try again. If you have 16.6 SXXX then make sure under Setup - Constraints - Modes - Electrical Modes that all differential pair checks are enabled.
