  3. Unable to define via structure
  • Views 14046
GK MN
GK MN over 6 years ago
Hello Friends
After long gap I am working on Oracd PCB editor 17.2  SO49 tool , and I was bit uncomfortable with the navigation in  17.2 compared to  earlier 16.6
I was trying to create custom via structure  but unable to do it , could you please suggest anything I am doing wrong in creation step (image attached) .
n 16.6 it was straight forward option !!!
Girish Kumar
  • LouShay
    LouShay over 6 years ago
    Hi Girish, The objects your selecting for the structure (via and cline) already belong to a structure (probably from an earlier attempt). You can verify this by setting your Find filter to Symbols and doing Info on the structure. You'll see the LOCKED property is applied. To remove the property; set the Find filter to Symbols; then Edit > Properties (Delete).
